Hi all,
I have the following data in txt file:
1,438246.753,1312422.091,10.1001,FdIP
2,438609.870,1308129.262,11.2002,SamplePt
3,438609.868,1308129.260,-50.2002,SamplePt
4,438550.143,1308130.676,12.3003,SamplePt
5,438550.141,1308130.674,-60.3003,SamplePt
6,438502.798,1308128.391,13.4004,SamplePt
7,438594.944,1308097.086,14.5005,SamplePt
8,438502.447,1308050.948,15.6006,SamplePt
9,438502.445,1308050.946,-75.6006,SamplePt
10,438549.784,1308097.364,16.7007,SamplePt
11,438508.630,1308096.788,17.8008,SamplePt
12,438641.585,1307945.910,10.1111,Boundary B
13,438678.693,1308186.785,10.2222,Boundary
14,438383.351,1308186.785,10.4444,Boundary
15,438383.351,1308080.539,10.3333,Boundary CLS
where 3 locations have the same XY-diffrent Z (point pairs: Pt2-Pt3, Pt4-Pt5, Pt8-Pt9).
In the AutoCAD Civil 3D 2014, I created a Survey Database "SDB FTMN", a Figure Prefix Database "FPDB FTMN", and a Linework Code Set "LCS FTMN", and the I imported the txt data via the Import Events of Survey Databases (I had Point identifier offset:1000 to start with). It worked OK without any Warning for the duplicate points. I got the DWG in 2D Wireframe that Pt1002&Pt1003, Pt1005&Pt1006, Pt1008&Pt1009 are showed as 3 points respectively - see the first attched jpg file. If i used the "Orbit" command to change the TOP view to other views for better viewing of separated Pt1002&Pt1003, Pt1004&Pt1005, Pt1008&Pt1009 in 3D Wireframe for the separated 2 depths - see the second attched jpg file.
1) I can save and print the DWG in 2D Wireframe (i. e.the 2D DWG showed in the first attached jpg file) without any problem.
2) I cannot save and print the DWG in 3D Wireframe (i. e. the 3D DWG showed in the second in the second attached jpg file), because the Pt#s, Elevation, and Description for all the points disappear completely (just the Boundary remains in the DWG), once I hit the "Save" or "Print" button under the File menu!!??
Please kindly help, advise me how to get the DWG in 3D Wireframe saved orprinted, and respond.
Scott Chang
