I installed the hotfix without any problems (or so I thought I did), but everytime I start C3D 2014 it says that I have the update to install, so I download it to my computer and double click on the executable and it tells me that "Your version of Autodesk AutoCAD Civil 3D 2014 is up-to-date and this service pack is not necessary".
If I go to the "About AutoCAD Civil 3D" under the help the HF1 does NOT show up next to my product version. So then I went to Control Panel - Programs and Features to View installed Updates and it does not show up there. I also did a repair of C3D with no luck. Any Ideas?
no clue
clearly from your screen shot of the product information it does not list hotfix 1 like it should if you installed it
so thats kind of wierd
DarrenP
I have the exact same problem.
Also, when logging into 360 crashed, I got an email reminder that the hotfix was not installed.
When I downloaded and installed it (again), got the same results.
I will ask if you are working off an SSD which has the no serial number issue (like I do).
