Civil 3D 2014
Trying to build a surface from grading objects and contours. I am getting 2k+ duplicate points. I've run OVERKILL five times, each time the dialog is reporting that duplicates are being removed. Great, but when I try to build my surface afterwards, they are all still there.
Any advice on how to strip them completely out of the drawing?
Thanks in advance,
Dan
Solved by antoniovinci. Go to Solution.
Do you have points that site on a breakline or user contours that cross a breakline? Is this for a survey?
If it's for a survey, typically anything I use to generate a breakline I will not add to the surface. This could be the problem??
Thanks for the reply. It is a dredging overdrepth surface. The contours are created from a 3D model, and are combined with 3D polyline grading entities. I kept all contours from instersecting the grading objects.
To compound the issue, when I bring the same data into LDD 2008, I see a data transformation error, where my max elevation is a Z value (e.g. 548 ft), and a minimum coordiante is a negative value.
I've run 5 successive OVERKILL's and they are still in the drawing.....
Dan,
I guess the following technique would be worth a try.
1] command _EXPORTPOINTS to a .CSV format
2] open the .CSV file in the great NoteTab Light freeware
3] VIEW => OPTIONS => TOOLS => SORT REMOVES DUPLICATES => OK
4] MODIFY => LINES => SORT=> ASCENDING
Doing so, you'll have the 100% sureness that your point list will contain unique XYZ triples.
Run the following commands:
overkill
mapclean
Good Luck
Khalid Mahmood
GIS/CAD Professional
kmc786pak@gmail.com
Saudi Arabia
