Civil 3D Forum
C3D 2013 Text Editor
3 REPLIES 3
d_whynot
2008 Views, 3 Replies
I recently installed C3D 2013 (stock intallation). I noticed when editing text that several buttons were missing from the ribbon (i.e. Strikthrough, upper/lower case. etc.) when using 2D Drafting and Annotation. They DO appear when using the C3D as AutoCAD link. I assume differfent menu loadings. But even standard C3D settings I cannot get all of the MTEXT features. Can someone enlighten?
Cheers!
Tags (1)
3 REPLIES 3
ToddRogers-WPM
in reply to: d_whynot
One option is to turn on the toolbar, which is show in the pic below...
Todd Rogers
d_whynot
Cool...the toolbar will help a lot. That's one level I haven't clicked into before. Still curious as to why it's not on the ribbon. I suspect it's an Autodesk oversight in the ribbon re-tooling. An item for Service Pack 1.
mathewkol
This isn't the first time. In 2012 the array context sensetive ribbon did not appear. You could more than likely fix it in the CUI editor without too much fuss.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Rail Community
