Civil 3D Forum
C3d 2013 Structure Change
2 REPLIES 2
bo.martin
329 Views, 2 Replies
I'm learning pipe network's....
I need to change a structure type and I can't seem to find
where I can change it.
TIA
Bo
2 REPLIES 2
ccoles
in reply to: bo.martin
It's easy. Click on the structure to highlight it, then right-click for the pop-up menu. On that menu, there's a command to 'Swap Part...'. It brings up the part catalogue to pick the next part to change it to. Be aware that this also updates the part description, so you may want to check that after you swap the part.
If the pop-up menu doesn't show a 'Structure Properties...' or 'Swap Part...', there must be 2 or more items highlighted. Hit ESC a couple of times and try again.
Windows 7 64-bit
Dell Precision T5610, Dual-Xeon 2.6Ghz, 16 Gig RAM
Civil 3D 2013
bo.martin
in reply to: ccoles
That got it.
You have to do it in plan view. In the profile view the swap part option wasn't there.
Thanks!!
Rail Community
