Civil 3D Forum
C3D 2013: Programming by Using .fbk CODES. Specs or Instructions?
1 REPLY 1
scottchang
717 Views, 1 Reply
Hi all,
I did the Survey Tutorial: Importing Field-Coded Survey Data - Survey 1. Survey-1.fbk (see the file below) from the Tutorial folder was used in the Tutorial.  FC1 VA 804 48.552410 82.746  88.374886 "BLDG7 RT 36 12 CLO" is wrong - it should be FC1 VA 804 48 552410 82 746 88 374886 "BLDG7 -RT 36 12 CLS" (I realized it from the Tutorial).  l wonder whether the Specs, Instructions or Documentation of the .fbk codes exit in the AutoCAD Civil 3D 2013 (or early versions of C3D) or Websites of third-party companies. Please kindly help and advise me where I can find/get the Specs/Instructions/Documentaion for programming the codes of the .fbk statements.
Thanks in advance,
Scott Chang
UNIT FOOT DMS
HORIZ ANGLE RIGHT
PRISM CONSTANT 0
PRISM OFFSET 0
EDM OFFSET 0
CR OFF
ATMOS OFF
COLLIMATION OFF
JOB LINEWORK SAMPLE
SCALE FACTOR 1.000000
VERT ANGLE ZENITH
NE 1 5000.000 5000.000 263.650 "STA1"
NE 6 5088.000 6104.000 249.635 "STA6"
AZ 6 6000 135.000000
AZ 1 1000 315.000000
STN 1 0.000000 "STA1"
PRISM 0.000000
FC1 VA 1000 0.000000 00.000 90.000000 "AZMK"
FC1 VA 2 117.563300 300.023 90.421692 "STA2"
FC1 VA 101 29.082602 91.481  89.454093 "SDWK1 B"
FC1 VA 102 28.024103 85.731  89.401866 "SHD1 B"
FC1 VA 103 27.134289 81.910  89.495311 "EP1 B"
FC1 VA 104 20.092686 59.515  89.171525 "EP2 B"
FC1 VA 105 19.192302 57.714  88.440647 "TC1 B H0.5 H-0.1 V-0.5"
FC1 VA 106 15.234405 50.640  88.011060 "CLM B"
FC1 VA 107 10.132014 43.849  88.193331 "TC2 B H-0.5 H0.1 V-0.5"
FC1 VA 108 8.402312 42.206  88.594830 "EP3 B"
FC1 VA 109 336.480464 26.931  89.292180 "EP4 B"
FC1 VA 110 328.294524 25.715  88.542934 "SHD2 B"
FC1 VA 111 315.000000 25.003  89.074501 "SDWK2 B"
FC1 VA 112 84.000234 20.591  90.352368 "WSO"
FC1 VA 113 135.000000 25.003  90.521499 "SDWK2"
FC1 VA 114 121.301476 25.711  90.360605 "SHD2"
FC1 VA 115 113.115536 26.935  91.062236 "EP4"
FC1 VA 116 81.193688 42.200  90.014753 "EP3"
FC1 VA 117 79.463986 43.833  89.191297 "TC2"
FC1 VA 118 74.361595 50.620  88.524570 "CLM"
FC1 VA 119 70.403698 57.702  89.290118 "TC1"
1 REPLY 1
tcorey
in reply to: scottchang
Check out the Survey Command Language reference here:
http://docs.autodesk.com/CIV3D/2013/ENU/index.html?url=filesCUG/GUID-919A5D8F-A06C-43E3-B102-90287EA...
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Rail Community
