Hi all,
I did the Survey Tutorial: Importing Field-Coded Survey Data - Survey 1. Survey-1.fbk (see the file below) from the Tutorial folder was used in the Tutorial. FC1 VA 804 48.552410 82.746 88.374886 "BLDG7 RT 36 12 CLO" is wrong - it should be FC1 VA 804 48 552410 82 746 88 374886 "BLDG7 -RT 36 12 CLS" (I realized it from the Tutorial). l wonder whether the Specs, Instructions or Documentation of the .fbk codes exit in the AutoCAD Civil 3D 2013 (or early versions of C3D) or Websites of third-party companies. Please kindly help and advise me where I can find/get the Specs/Instructions/Documentaion for programming the codes of the .fbk statements.
Thanks in advance,
Scott Chang
UNIT FOOT DMS
HORIZ ANGLE RIGHT
PRISM CONSTANT 0
PRISM OFFSET 0
EDM OFFSET 0
CR OFF
ATMOS OFF
COLLIMATION OFF
JOB LINEWORK SAMPLE
SCALE FACTOR 1.000000
VERT ANGLE ZENITH
NE 1 5000.000 5000.000 263.650 "STA1"
NE 6 5088.000 6104.000 249.635 "STA6"
AZ 6 6000 135.000000
AZ 1 1000 315.000000
STN 1 0.000000 "STA1"
PRISM 0.000000
FC1 VA 1000 0.000000 00.000 90.000000 "AZMK"
FC1 VA 2 117.563300 300.023 90.421692 "STA2"
FC1 VA 101 29.082602 91.481 89.454093 "SDWK1 B"
FC1 VA 102 28.024103 85.731 89.401866 "SHD1 B"
FC1 VA 103 27.134289 81.910 89.495311 "EP1 B"
FC1 VA 104 20.092686 59.515 89.171525 "EP2 B"
FC1 VA 105 19.192302 57.714 88.440647 "TC1 B H0.5 H-0.1 V-0.5"
FC1 VA 106 15.234405 50.640 88.011060 "CLM B"
FC1 VA 107 10.132014 43.849 88.193331 "TC2 B H-0.5 H0.1 V-0.5"
FC1 VA 108 8.402312 42.206 88.594830 "EP3 B"
FC1 VA 109 336.480464 26.931 89.292180 "EP4 B"
FC1 VA 110 328.294524 25.715 88.542934 "SHD2 B"
FC1 VA 111 315.000000 25.003 89.074501 "SDWK2 B"
FC1 VA 112 84.000234 20.591 90.352368 "WSO"
FC1 VA 113 135.000000 25.003 90.521499 "SDWK2"
FC1 VA 114 121.301476 25.711 90.360605 "SHD2"
FC1 VA 115 113.115536 26.935 91.062236 "EP4"
FC1 VA 116 81.193688 42.200 90.014753 "EP3"
FC1 VA 117 79.463986 43.833 89.191297 "TC2"
FC1 VA 118 74.361595 50.620 88.524570 "CLM"
FC1 VA 119 70.403698 57.702 89.290118 "TC1"
Solved by tcorey. Go to Solution.
Check out the Survey Command Language reference here:
