Distinguished Contributor
ccookusi
Message 1 of 7 (766 Views)
C3D 2013 Profile Linetype generation
766 Views, 6 Replies
08-22-2012 05:23 AM
This does not seem to be working in 2013 when the profile is a reference.
Any ideas?
Windows 7 Pro x64
Civil 3D 2015
Dell Precision T1650
i7 3770
NVIDIA Quadro 2000
SSD Boot
16 GB Ram
LisaPohlmeyer
Message 2 of 7 (738 Views)
Re: C3D 2013 Profile Linetype generation
08-22-2012 11:44 AM in reply to: ccookusi
If it helps any, I can replicate this.  Seems to work fine in 2012.
Lisa Pohlmeyer
C3D 2012 SP4, C3D 2015
Please use "Accept as Solution" if this solved your issue.
Employee
hgohel
Message 3 of 7 (682 Views)
08-29-2012 01:03 PM in reply to: ccookusi
We have filed defect 1471381 to track this.  Thank you for your report.
Himanshu Gohel
Autodesk, Inc
Valued Contributor
kolk
Message 4 of 7 (639 Views)
10-19-2012 07:34 AM in reply to: hgohel
Has there been any resolution to this issue yet?
ceethreedee.com
Message 5 of 7 (571 Views)
11-14-2012 07:04 PM in reply to: kolk
Profile Linetype generation will not work for "surface" profiles that are data shortcutted.
The surface profile needs to be created in the drawing that contains the profile view.
Its okay to dref design profiles though, jsut not surface profiles. You will also notice that surface profiles that are dreffed are static and not dynamic! Not sure if this is how autodesk intended the workflow to be though.
Regards
Kapanther
Civil 3D 2014 (SP2)
Win 7 Pro x64 -DELL Precision Workstation T3500
Intel Xeon 3.3GHz (w3680) -24Gb Ram
NVIDIA Quadro 2000 (1GB)
ceethreedee.com
Employee
hgohel
Message 6 of 7 (552 Views)
11-16-2012 05:57 AM in reply to: ceethreedee.com
DRef surface/dynamic profiles are treated as static in the drawings in which they are referenced and that is the expected behavior. That said, if the surface is updated and references are synchronized the profile will update.
Himanshu Gohel
Autodesk, Inc
New Member
pmahobian
Message 7 of 7 (215 Views)
11-19-2013 02:58 PM in reply to: kolk
Synchronize the profile in the referenced drawing... that should fix the issue.
