Hi all,
In my AutoCAD Civil 3D 2013, I created a parcel from 4 lines. I selected the parcel (Property : 1) to get the Properties tab and edited the Style of my parcel: (i) changed Property : 1 to NewLOT : 1 in Name. (ii) added 22.5 mg/Kg Arsenic; 33.6 mg/Kg Lead; 66.9 mg/Kg Mercury to Description. In the drawing area, NewLOT : 1 appears, but, there are no 22.5 mg/Kg Arsenic, 33.6 mg/Kg Lead, 66.9 mg/Kg Mercury shown up below the NewLOT: 1 line - see the attached file. Please kindly help and tell me how to bring the chemical data from the Description of my parcel to the drawing area.
Thanks in advance,
Scott Chang
Hi Dan, Thank you very much for your nice, valuable resonses for this thread and the other one.
I tried to do what you instructed. I went to Settings => Parcel => Label Styles => Area => Parcel Name (see the ist attached file), => I got Label Style Composer Name (see the 2nd attached file), not Text Composer Editor - Contents (your 1st attached file). I don't know to get Text Composer Editor - Contents to do the job I need to edit. Please kindly help and give me more detailed instructions for getting Text Composer Editor - Contents for editing I need to do.
Please respond again,
Many Thanks,
Scott Chang
Hi Dan, Thanks for your nice response.
It works nicely. I got what I want and your nice instructions cleared my mind about showing the chemical results listed in Description and DWG see the 1st attached file. I turned the Rotation Cube to the north to get a TOP-Front viw. The "NewLOT : 1" and "Chemical Results/Data" became blurred - see the 2nd attached file.
Three questions to ask you:
Q#1: In the 1st attached file, why do I get the white bachground?
Q#2: In the 2nd attached file, why do I get the black background?
Q#3: After I turned the Rotation Cube, why do I get the blurred "NewLOT : 1" and "Chemical Results/Data"?
Many Thanks again,
Scott Chang
