Civil 3D Forum
C3D 2013:Importing Survey Data; Figures-Line Codes in has ! in Yellow Shield
3 REPLIES 3
scottchang
487 Views, 3 Replies
Hi all,
In my AudoCAD Civil 3D 2013 program, I set up a network and imported a survey data listed below:
===suv2-Figures-LineCodes_H28-H30_BldgB.txt====
1,5000.0000,10000.0000,77.2507,FdIP
2,5047.4285,9999.5818,78.6023,FencePost B
3,5047.6924,9987.9653,77.7915,FencePost
4,5047.1646,9974.7648,76.7385,FencePost
5,5047.1646,9957.3400,75.3846,FencePost
6,5046.9007,9945.4595,74.4644,FencePost
7,5046.9007,9933.8430,73.6032,FencePost
8,5047.1646,9921.4345,72.7112,FencePost E
9,5044.7895,9960.7722,75.5783,pool B BC
10,5045.0534,9954.6999,75.1165,pool
11,5042.6783,9950.4757,74.7183,pool
12,5038.7199,9949.1557,74.5003,pool
13,5039.2477,9953.9079,74.8880,pool
14,5037.9282,9958.1321,75.1797,pool
15,5040.3033,9962.6202,75.5959,pool EC CLS
16,5030.3992,9937.2577,73.4284,BLDG B
17,5012.4025,9937.2577,73.1133,BLDG
18,5012.4025,9946.7723,73.8531,BLDG
19,5016.0604,9946.7723,73.9189,BLDG
20,5016.0604,9948.8216,74.0786,BLDG
21,5010.2078,9948.8216,73.9689,BLDG
22,5010.2078,9961.2638,74.8305,BLDG
23,5018.5477,9961.2638,75.0888,BLDG
24,5018.5477,9957.8971,74.8264,BLDG
25,5028.9361,9957.8971,75.0113,BLDG
26,5028.9361,9946.7723,73.4284,BLDG
27,5030.3992,9946.7723,73.4284,BLDG E
28,5010.5005,9928.7677,72.4282,BLDG B
29,5026.5950,9928.7677,72.7032,BLDG
30,5026.5950,9924.3764,72.3679,BLDG
31,5028.7897,9924.3764,72.4058,HOUSE
32,5028.7897,9910.1777,71.3592,HOUSE
33,5014.3046,9910.1777,71.0771,HOUSE
34,4996.4421,9998.1000,76.9104,LOG B
35,4995.5734,9977.0976,75.5193,LOG
36,4994.9943,9948.1286,73.5023,LOG
37,4994.2704,9921.0427,71.5496,LOG
38,4994.5600,9909.1654,70.6753,LOG BC
39,4996.7317,9903.0819,70.2459,LOG
40,5001.2199,9899.0263,70.0084,LOG
41,5008.4589,9898.1572,70.0576,LOG
42,5016.5667,9899.7505,70.3261,LOG
43,5028.2940,9903.0819,70.8335,LOG
44,5037.7047,9907.8618,71.4119,LOG
45,5045.8125,9914.6695,72.1788,LOG
46,5051.8933,9921.7669,72.8921,LOG EC
47,5014.3046,9916.1985,71.5334,HOUSE
48,5010.5005,9916.3256,71.4761,HOUSE
49,5012.1099,9990.2467,76.9132,BLDG B
50,5020.5961,9990.2467,77.1798,BLDG RT x0 -2.05 11.41 -21.23 -17.85 -9.66 2.05 CLS
by using PNEZD (comma delimited) in Figures-LineCodes => Import =>Import point file.  I just got the 50 points without the figures, and there is a "!" in a yellow shield in front of Figures-LineCodes - see the attached file.  I think I made a mistake in the Code Line # 28 with "B" and the Code Line 30 without "E" that causes the "!"  in the yellow shield in front of Figures-LineCodes.  I don't know how to resolve this problem.  Please kindly help and advise me how to resolve this problem.
Thanks in advance,
Scott Chang
3 REPLIES 3
ToddRogers-WPM
in reply to: scottchang
Right click on it and select Update.
Todd Rogers
scottchang
in reply to: ToddRogers-WPM
Hi Todd, Thanks for your nice, valuable response.
I did "Update" as you instructed. The "!" in Yellow Shield was gone.  Only 50 points appeared - no figures of  "Line", "Pool", "BLDG", "LOG" on the drawing - see the attached file. 2 new things to ask you:
1) In the Line 50 statement of the Codes, what do the "x0 -2.05 11.41 -21.23 -17.85 -9.66 2.05 CLS" mean?  Please tell  me the meaning of this set of Codes.
2) If I correct the codes for the Lines 28 thru 33 in the txt file, how can I re-import the corrected txt file to get the right fire?
Please kindly help and respond again.
Many Thanks again,
Scott Chang
stacy.dunn
#1
The code for point 50 will create a building using the offsets from a line created between point 49 and 50.  the x0 command is to extend the line from 49 to 50 before drawing the offsets.
In the attached screenshot, I changed the x command to match our linework code set EXT.
#2
If you have not done alot of edits in the drawing, you can simply delete the import event in the survey database and re-import the corrected file.  This will erase the points and linework in the drawing.
Stacy Dunn
Rail Community
