Cross hairs, view cube, x and y axis all flickering.
The problem is specific to one drawing and goes away after closing and re-opening. The problem is triggered by opening the "volume dashboard".
It's worth noting that I have two volume surfaces that have cut and fill elevation analysis applied to them, displaying different levels of cut and fill. The problem occurs both with the volume surfaces displayed or not.
This is not something we do often here, but from time to time.
Also - just FYI - I am operating with hardware acceleration turned "off", which is how we (all of our designers) keep our workstations set.
Thanks - rsbria
C3D 2013 SP2
i7 3.4 ghz
16 gb Ram
64-bit
Windows 7 Pro
In the past it has been cured by turning the Hardware Acceleration OFF, then back on. In your case perhaps turn it ON then back OFF.
It made no sense but normally worked.
Bill
A couple of things that always works for me is to keep the layer palette CLOSED. Having the layer palette running in "real time" slows things down and causes that cursor "flicker". I prefer using the "old fashioned" layer dialog box (either use the CLASSICLAYER command, or set LAYERDLGMODE to 0)
Another trick to speed the layer manager up (eithe the tool palette OR the dialog box) is to set SHOWLAYERUSAGE to zero
