Civil 3D Forum
C3D 2013 Deployment Creation
2 REPLIES 2
jnelson1071
579 Views, 2 Replies
I have a question and don't know if someone could clear this up for me?
What does the deployment option to "Include only products required by this deployment configuration" actually mean?
The way I'm reading the documentation, if something does come out to add to the deployment (aka: Subscription Advantage Pack) if I select this now, then I would have to build a new deployment to then include these? As it was, it took me 3.5+ hours to create the first deployment. Should I have this unchecked then I would be able to append the deployment to add items down the road?
http://docs.autodesk.com/CIV3D/2013/ENU/filesCIO/GUID-DA4B72C7-205E-4ED5-B736-A11416677A35.htm
"If selected, the deployment cannot be modified in the future to include additional products. If unselected, the administrative image will include all possible products, and the deployment can be modified in the future in any way."
What are "Possible Products" anyways?
2 REPLIES 2
GTVic
in reply to: jnelson1071
jnelson1071
in reply to: GTVic
My bad.  I looked over that one and will post in right forum. Thank you for pointing this out.  I can't modify where this is posted or delete from my end, but if the moderator would like they can remove this post.
For now here is the new post in the right forum.
http://forums.autodesk.com/t5/Installation-Licensing/C3D-2013-Deployment-Creation/td-p/3401551
Rail Community
