Civil 3D Forum
C3D 2013-Data shortcut surface profile views?
5 REPLIES 5
rpeery2
2645 Views, 5 Replies
I've created surface,alignments, surface profiles and pipe networks into a dwg call topo.  I'm trying to data reference these surface profile views in my construction plan drawing so I can drawing my proposed pipe network into the same surface profile views.  Seems like at can data reference in everything but the surface profile views.  Any suggestions??
5 REPLIES 5
troma
in reply to: rpeery2
You can't d-ref a profile view, per se.
You d-ref the alignment, and the profile. Then in the other drawing you can recreate the profile view using the same alignment and profile.
Mark Green
Working on Civil 3D in Canada
ericcollins6932
Or xref the file if you like the way your profile view is.
Eric Collins, P.Tech.(Eng.)
Win 10
Intel i7 9700 @ 3 GHz
16 GB RAM
Civil 3D 2019
rpeery2
in reply to: ericcollins6932
Eric,
If xref the topo/profile views in your const doc drawing how would you add your proposed pipe network to the xref profiles???
ericcollins6932
Ah, you didn't say you wanted to add data. Make shortcuts of the profiles, alignment and surface and create a new profile view in your pipe drawing after drefing in everything.
Win 10
16 GB RAM
Civil 3D 2019
troma
You don't need the surface. You can reference the surface profile.
Mark Green
Rail Community
