Hi all,
I used PENZD file that has 8 points (4 locations with 2 depths in each location) to create a Point dwg that has several annotations I made. Then I used the "Lines/Curves" => "Create Lines" by "Point # Range" to create 6 sets of lines: Line Set #1 that connects Points 1-3-5-7-1, Line Set #2 that connects Points 2-4-6-8-2, Line Set #3 that connects Points 1-2, Line Set #4 that connects Points 3-4, Line Set #5 that connects Points 5-6, Line Set #6 that connects Points 7-8. The annotaions for the 8 points are gone, after I completed the creation of the Lines. I wonder whether I can create 2 layers in the AutoCAD Civil 3D 2013: 1 layer for the 8 points with my annotations attached and 1 layer for the lines I created from the 8 points. Please kindly help and advise.
Scott Chang
Hi Kirk, Thanks for your response.
I used the AutoCAD Civil 3D (Imperial) NCS.dwt to start my DWG and to create the 8 points first and then the lines from the 8 points. Please tell me which DWT I should use for getting the 2 Layers of Popints and Lines I need - see the attached file that shows the most DWT files in the AutoCAD Civil 3D 2013 program. Please kindly help and respond again,
Thanks again,
Scott Chang
