Why does C3D 2013/2014 randomly eliminate grading and/or grading feature lines when performing other grading/transition functions? Even just this morning, I performed a purge and audit, which resulted in 114 errors found and fixed. And when it did the fixing, it also erased a vast majority of the grading throughout a 2200 foot corridor. There seems to be no rhyme or reason to it.
I always do an Audit before every save. I may do this 4-6 times an hour. It just come naturally if you apply a "short hand" to each operation.
Bill
To gain a little insight Google, "Civil 3D Grading" without the quotes and notice the number of links.
Now Google, "Civil 3D corrupt grading" and note the number of links.
John Mayo
@Anonymous wrote:I always do an Audit before every save. I may do this 4-6 times an hour. It just come naturally if you apply a "short hand" to each operation.
Bill
Thank you, Bill. While I do not perform an audit prior to every save, I do perform them regularly during my AutoCAD sessions. It still begs the question as why some feature lines and at times, entire sections of grading disappear when performing other grading commands. Today was the first time an audit deleted major portions of grading for me.
When I did this on the 12th it was alomost 2 million more...
Some of my rules.
Do not leave live gradings in a final design file. I'm ok with rebuilding a few gradings EARLY in a project when the design is being fine tuned. Once the design is final, copy the base feature line and resulting grading feature lines to a new site and build FG with these. Delete the site grading site.
or if you are working with grading surfaces, detach the surface from the grading and then delete the site.
John Mayo
@jmayo wrote:When I did this on the 12th it was alomost 2 million more...
Some of my rules.
Good advice, John. Thank you. However, I can't seem to get C3D to let me get to a final design. I've even moved any alignments to a different site just on the off chance they are impacting the grading. No parcels are built yet so I know that is not an issue. It seems to just rnadomly delete a daylight grading or a feature line defining the exterior of a grading randomly throughout the project when I am performing a grading function, for example. If I attempt to edit a grading, it may just delete half of it all! FYI, this is the second attempt at grading this particular project. I started this second dwg from a clean copy.
