Civil 3D Forum
C3D 2013 & dll's
6 REPLIES 6
neilyj666
549 Views, 6 Replies
C3D 2013 & dll's
Seems like all my existing dll's won't work in C3D 2013 without some code alterations - fantastic......!!!!!!
A small QA point - someone didn't check the names on the panels to ensure consistency. I know its a minor thing that's easily fixed but come on AutoDesk
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
6 REPLIES 6
Jeff_M
in reply to: neilyj666
Many customization files targeting C3D have needed to be recompiled for new versions every year. Those that didn't were able to be done using strictly .NET API.objects. But the AutoCAD 2013 API has undergone major changes, and C3D2013 has also made major changes in the API. So ALL .NET DLL's wiil not only need to be recompiled for 2013, but they will also need to undergo some code updates before compiling.
Not sure I'm seeing what you are about the names.
Jeff_M, also a frequent Swamper
neilyj666
in reply to: Jeff_M
..thus rendering all the dll's I use in 2012 useless.....Smiley Sad
Inconsistency with the naming i.e TRIM rather than Trim and fillet rather than Fillet - I've got the European English version so could be different to yours. I've fixed it now anyway - and put the Volumes calculation back on the Ribbon
neilyj666
Jeff
A few months ago you modified some Autodesk supplied code to run as a dll (C3D Working Plane) - would you be able to update for 2013??
http://forums.autodesk.com/t5/AutoCAD-Civil-3D-Customization/Working-Plane-Grading-tools/m-p/3310593...
Jeff_M
On my list of things to do. Now, if only I would be provided with the 2013 download on Subscription center....not sure of when I may be able to do this. (But probably fairly soon.)
neilyj666
in reply to: Jeff_M
That'd be great if you could manage it,,,,my subscription download worked first time using the download manager today
Jeff_M
Still not even available to me on Subscription....
However, since I have other means available (ADN) have a look HERE
Rail Community
