Valued Contributor
gauss2069
Message 21 of 29 (841 Views)
Re: C3D 2012 vs. C3D 2011
04-20-2011 11:05 AM in reply to: gauss2069
Allen, Thanks. I had a chat with Norton. Norton was kicking AutoCAD programs big time. Now I am protected with the http://www.symantec.com/norton/support/kb/web_view.jsp?wv_type=public_web&ssfromlink=true&sprt_cid=f... Happy modelling!
Civil 3D x64 2013
Win 7 x64
Intel Core i7-940XM
8 GB RAM
Quadro FX 5000M
AllenJessup
Message 22 of 29 (836 Views)
04-20-2011 11:07 AM in reply to: gauss2069
You're welcome. I've has similar experiences myself with Norton.
Allen
Distinguished Contributor
jmatthei
Message 23 of 29 (807 Views)
04-20-2011 01:19 PM in reply to: Jason.Hickey
Jason:
Thank you for acknowledging the request.  I do hope I'm not the only one asking for it.  I'll be the first at my company to try out and propose using whichever software does it competently first.  So far I've heard that Revit MEP + EaglePoint Site Works is close to it, although I have my doubts that it would work as seamlessly as some say....
--Jeremy
GTVic
Message 24 of 29 (787 Views)
04-20-2011 01:58 PM in reply to: jmatthei
Speaking of object enablers, why is it that there is an object enabler install right at the end of the installation process? Is that new? Wouldn't think the object enabler is needed for the product that is being installed.
Greg
jmatthei
Message 25 of 29 (785 Views)
04-20-2011 01:59 PM in reply to: gauss2069
My guess is it enables Revit objects to be viewed in C3D.
Employee
Matt.Anderson
Message 26 of 29 (751 Views)
04-20-2011 08:27 PM in reply to: GTVic
Greg
The Object Enabler is installed onto Autodesk Storm and Sanitary Analysis 2012 which is installed at the tail end of the installation.
Matthew Anderson, PE
Product Manager
Westhills
Message 27 of 29 (662 Views)
04-28-2011 11:08 AM in reply to: gauss2069
Here goes. Regarding my issue earlier in this thread regarding the lag. After some back and forth and collaborating, Autodesk called me today to say there indeed was an issue that is problematic with CAD 2012. For me it was manifested by the number of layers exceeding some number. Apparently this issue manifests itself in opther ways aswell. I was advised this has gone straight to the top of the chain of command and is requiers a hotfix immedialty. So there you have it. Hotfix on the way!
Win 7 64bit
16 Gigs Ram
Intel i7 870
Quadro fx1800
C3D 2011/2012
ASUS Custom
Dual 24 Phillips screens
Active Contributor
dkaven
Message 28 of 29 (471 Views)
08-01-2011 08:36 AM in reply to: jbear0000
I've been working with 2012 sine the box hit my desk. I notice a few things but not real big. The things I've noticed is the dtext problem when editing, I've been having some problems in the 32 bit install were I create a new layer and then try to change the color but the color want take ( only in 32 bit).
Another thing I've noticed is some feature line/brake lines problems. The problem seems to be after I add new feature lines to an existing surface some of the existing feature line/brake line loses there effect on the surface. But note they worked and had effect on the surface prior to the newly added feature lines/brake lines. Also note these added feature lines are in a total different area of the surface so should not affect the feature lines/brake lines. So what I needed to do was explode the feature lines that no longer had effect on the surface, and then use the command “create feature lines from object”, and then add the feature line back into the surface as brake line.
Please let me know if you have any questions etc.
Danny
Joe-Bouza
Message 29 of 29 (447 Views)
08-01-2011 11:40 AM in reply to: civilspace
Isn't it ironic that all the fruit is out-on-the-limb. :smileywink:
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
