Hi my program crashes when attempting to edit a pipe network. specifically when trying to draw a pipe the program crashes the instant I select the second point to place the pipe. Anyone know how to fix this. others in my company can work with the pipe networks fine.
BP
I have no idea.
Perhaps your software & hardware spec's would help someone to think of a problem. But if your setup is the same as coworkers with no problem, then it's something else.
MIight have to try a repair on the installation.
Mark Green
Working on Civil 3D in Canada
Do you have any other complicated parts to your drawing such as a really detailed surface?
Also try restarting your computer and trying again.
Windows 7 Enterprise Intel Xeon CPU E3-1270 V2 3.5GHz 16GB RAM NVIDIA Quadro 600 C3D 2012
No Large Surface in Drawing. Error occurs even in a fresh drawing from template. (attached)
