Distinguished Contributor
mdriver1
Message 1 of 8 (1,784 Views)
C3D 2011 volume report (TIN Volume Surface)
1784 Views, 7 Replies
09-02-2010 02:26 PM
I generated a TIN Volume surface and have generated a report using reports manager (generic surface report built in) but the cuts/fills do not show the adjusted values just the unadjusted.
Mark Driver
BrianHailey
Message 2 of 8 (1,736 Views)
Re: C3D 2011 volume report (TIN Volume Surface)
09-06-2010 10:20 AM in reply to: mdriver1
As a work around, go into the properties of the volume surface, on the statistics tab, expand out the volume section, right click, and copy all. Paste were you need the info and then edit as needed.
Brian Hailey
CAD-1.com
My Blog
mdriver1
Message 3 of 8 (1,731 Views)
09-06-2010 10:49 AM in reply to: BrianHailey
Yes I did that but the point is this.....
shouldn't that just be there? I mean what good is a report if the adjustments are not there?
Not griping at you just making a point.
Thanks for your reply.
Mark Driver
BrianHailey
Message 4 of 8 (1,717 Views)
09-06-2010 06:16 PM in reply to: mdriver1
Ah, so you weren't actually looking for help, you were pointing out a flaw (or perhaps, a better term, would be lack of functionality).
Brian Hailey
CAD-1.com
My Blog
annw2
Message 5 of 8 (1,585 Views)
10-12-2010 04:47 AM in reply to: mdriver1
I will continue the discussion of volume reports.
I did the surface - utilites - volume - selected several to get individual volumes.
I then hunted to try to find a way to get the program to print to paper.
No print option here.
How about a summation option?
Exported out a xml, then had no means of doing anything with it.  Report manager doesn't seem to have an option for this list of volumes
coming back into this function later, the list of volumes had disappeared and had to be redone from scratch.
Civil 3d 2009 doesn't save this list?
Am I missing stuff or does this go into the wish list area?
Ann Wingert, P.E.
Jeff_M
Message 6 of 8 (1,569 Views)
10-12-2010 06:37 AM in reply to: annw2
The Export to XML is what saves the list for you. Use the Import from XML to get the list of volumes back into the Panorama.
In the Panorama, right click one of the rows, you will have the option to Copy Selected or Copy All. Then you can paste into Notepad, Word, Excel, MTEXT......
And now I see you are asking about 2009 even though you posted in a thread regarding 2011. I don't recall for sure if 2009 had all these options.
annw2
Message 7 of 8 (1,555 Views)
10-12-2010 09:47 AM in reply to: mdriver1
Thanks for reply.
The 2011 post was the only one that popped up with the subject.
Hope to have access to 2011 when new computer comes in.
Ann Wingert, P.E.
Jeff_M
Message 8 of 8 (1,553 Views)
10-12-2010 09:56 AM in reply to: annw2
You're welcome.
I just checked a 2009 install and these same options are available in that version as well. Edited to add that I was also able to import the XML created in 2011 to 2009.
