Civil 3D Forum
C3D 2011 "Paper" background
17 REPLIES 17
Message 1 of 18
lassi_tarri
1379 Views, 17 Replies
How can I change the colour of the "paper" background (in layout)?
17 REPLIES 17
Message 2 of 18
bjones9975
in reply to: lassi_tarri
type options, then go to the second tab (it's labeled 'Display')
about half way down on the left side you'll see a button that says 'Colors'
on the left you'll see a selection called 'Sheet / layout' then on the right side just change the color to what ever you want it to be.
Brian
Message 3 of 18
Is it possible to change the layout background? I hate 2011's new
whitish color.
EB
Win7 Pro 64-bit
Civil 3D 2011 64-bit
6GB RAM
Message 4 of 18
Hi Srayos,
Read and try Brian's post. Note that you can open the Options form in
several ways. I use op which is very quick to type.
Laurie Comerford
> whitish color.
> EB
> Win7 Pro 64-bit
> 6GB RAM
Message 5 of 18
Paper background options have not changed as far as Civil 3D been around (2005 or so).
Message 6 of 18
lassi_tarri
I know perfectly well how to access options. It's just that I can't find option for changing this new whitish paper background color in layout.
Message 7 of 18
MikeEvansUK
Switch to layout.
Envoke Options, select display tab, colours then change the sheet/layout colour uniform background colour to desired.
Mike Evans
Civil3D 2022 English
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
Message 8 of 18
lassi_tarri
I must be a bit of simple minded but.. Uniform background color changes the color of the paper? I want to change the surrounding background color.
Message 9 of 18
Just place a "big fat" polyline around it. Select your favorite color.
Bill
wrote in message
news:6377144@discussion.autodesk.com...
Message 10 of 18
Like what the original poster asked, I want to change the layout
background, not the paper background color. The old neutral gray color
was perfect against the white paper and shadow, but now it's more
difficult to see with the whitish background and white paper for the layout.
EB
Win7 Pro 64-bit
6GB RAM
On 4/20/2010 4:32 PM, Laurie Comerford wrote:
> Hi Srayos,
> Regards,
> Laurie Comerford
>> whitish color.
>> EB
>> Win7 Pro 64-bit
>> 6GB RAM
Message 11 of 18
lassi_tarri
Maybe it's easier to dim monitor or wear sunglasses?
Message 12 of 18
ACADuser
The only method I know of is to turn off display of the background. Your background will then match the color of your sheet. Options...Display Tab...Layout elements, then uncheck "Display paper background".
ACADuser
Civil 3D 2018, Raster Design 2018
Windows 7 Enterprise
Dell Precision 5810 Workstation
Intel Xeon E5-1630 v3 @ 3.70GHz
32GB RAM, NVIDIA Quadro K2200 4 GB GDDR5
DUAL 27" Dell UltraSharp U2713HM
Message 13 of 18
itr0045
This is obviously a new feature to 2011 and you're just taking it the wrong way. I am struggling with this as well of it makes you feel any better.
Message 14 of 18
ACADuser
I apologize if you took my reply as being condescending as I meant no disrespect. From lassis attachment I can clearly see how the paper shadow blends in with the new lighter background color. I never did like the way the ps layout looks with the shadow on so in the options I turn off the paper shadow. This way there are only two colors, the paper and the background. I would recommend you doing the same and see it helps.
The only other option is turning off the paper background as previously suggested, unless of course you have the ability to hack the program and modify the code to change the color.
Happy Civil 3D'ing 🙂
ACADuser
Message 15 of 18
itr0045
LOL, I was being the smartas s ACADuser. No harm! I hate this "new thing" with 2011 as well. This is one the first things that I attempted to change upon installation.
Message 16 of 18
klugb
I bet it's the same guy that came up with the default bright blue model space color in 2008 (i think) 🙂
Didn't they fire him?
It's actually quite entertaining because our survey department always seems to screw up their cad profiles and you see them working with the bright blue background all the time.
Bruce
Bruce Klug, P.E.
AutoCAD Expert Elite Alumni
AutoCAD Civil 3D Certified Professional
Civil 3D 2023.2.1
Win 10 Enterprise, 64-bit
Message 17 of 18
CRWYNNASSOC
I hate this as well. Nothing other than turning off the paper background seems to work.
Message 18 of 18
dear lassi_tarri.
you are not simple minded. why is it noone seems to understand the question or the issue.
i am with you and i am in a year long search to find the answer to this problem.
i canNOT stand the whitish gray. i want darker gray back!
Robot Mad
Rail Community
