Civil 3D Forum
C3D 2010 .sid files shift if view rotated
8 REPLIES 8
Message 1 of 9
Topher5000
1946 Views, 8 Replies
When I rotate my view in drawings containing .sid orthos, the orthos shift.  This also happens when I rotate the view in a viewport.  I've attached a couple screen caps showing the problem.  Any ideas how to fix this?
8 REPLIES 8
Message 2 of 9
dgordon
in reply to: Topher5000
have you tried plotting the view to see if it corrects itself?
have you searched this forum for other related posts?
Dan
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
12Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
Message 3 of 9
ToddRogers-WPM
If I'm not mistaking, this was an issue in 2010.
Todd Rogers
Message 4 of 9
Topher5000
in reply to: ToddRogers-WPM
I searched for 'sid shift'.  The closest thing to a fix was turning perspective on & off, but the UCS icon turns into the 3D icon & polylines with width aren't filled.
It doesn't plot out correctly either (see attached).
I've read posts that it could be the file size (the one I'm using is big - about 4.2gb) & that it also happens in C3D 2010.
Message 5 of 9
AlmasSuljevic
I have seen this behavior with the 2010 version if there is a viewport that has a DVIEW Twist applied to the viewport. I believe this was fixed in later releases. If you are using the DVIEW in the viewport, set the rotation to some 90 degree increment (0, 90, or 180) and see if the image lines back up with the linework as expected. Also see if you can bypass Data Connect and just insert the image into the drawing using "Insert Image".
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Autodesk, Inc.
Please click on "Accept as Solution" if post helped you resolve the issue.
Message 6 of 9
Topher5000
in reply to: AlmasSuljevic
Hi again Almas.
I've tried inserting it with mapiinsert, a straight image insert & then scaling & positioning it, using the FDO connection, & xrefing it into another drawing, but it still does it.  I was going to move my linework to match the aerial in the viewports but the apparent position changes depending on how far I'm zoomed in.  Is there anything else to try?  We've got a public meeting coming up & I need to get this sorted out.
Message 7 of 9
Topher5000
Got it working.
I downloaded GeoViewer from Lizardtech, opened the sid file & zoomed into the area I needed.  I then exported the current view to a geotiff file with a world file.  I did this along my route for total of 26 tiffs.  Each one has a resolution of 3463x2406 pixels.
For some reason they didn't end up in the exact same location as the original so I had to move my e/p linework to match, but, eh, it works.  The ortho no longer shifts around as I zoom in & out & rotate my view.  As a bonus, opening, saving & zooming is quicker & smoother.
Message 8 of 9
SteveXXX
Having same proble of viewport image shift using geolocate aerial.  Brought the image into individual sheets and move the xref line work to match image worked.
Message 9 of 9
yosephk
I think  bypassing Data Connect and just inserting the image into the drawing using Insert Image worked for me.
Windows 10 Pro x 64
16 GB Ram
Intel Xeon E3-1220 V2 @ 3.1 GHz
NVIDIA Quadro 600
Civil 3D 2019
Rail Community
