Valued Contributor
Topher5000
Message 1 of 8 (472 Views)
C3D 2010 .sid files shift if view rotated
472 Views, 7 Replies
02-01-2013 11:58 AM
When I rotate my view in drawings containing .sid orthos, the orthos shift.  This also happens when I rotate the view in a viewport.  I've attached a couple screen caps showing the problem.  Any ideas how to fix this?
Got it working.
I downloaded GeoViewer from Lizardtech, opened the sid file & zoomed into the area I needed.  I then exported the current view to a geotiff file with a world file.  I did this along my route for total of 26 tiffs.  Each one has a resolution of 3463x2406 pixels.
For some reason they didn't end up in the exact same location as the original so I had to move my e/p linework to match, but, eh, it works.  The ortho no longer shifts around as I zoom in & out & rotate my view.  As a bonus, opening, saving & zooming is quicker & smoother.
*Pro
dgordon
Message 2 of 8 (470 Views)
Re: C3D 2010 .sid files shift if view rotated
02-01-2013 12:07 PM in reply to: Topher5000
have you tried plotting the view to see if it corrects itself?
have you searched this forum for other related posts?
Dan
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
12Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
TRogers
Message 3 of 8 (463 Views)
02-01-2013 12:33 PM in reply to: Topher5000
If I'm not mistaking, this was an issue in 2010.
If the issue was resolved by this method, please click on "Accept As Solution"
*Civil 3DJ*
Todd Rogers
Visit my blog here.
Valued Contributor
Topher5000
Message 4 of 8 (456 Views)
02-01-2013 01:23 PM in reply to: TRogers
I searched for 'sid shift'.  The closest thing to a fix was turning perspective on & off, but the UCS icon turns into the 3D icon & polylines with width aren't filled.
It doesn't plot out correctly either (see attached).
I've read posts that it could be the file size (the one I'm using is big - about 4.2gb) & that it also happens in C3D 2010.
Product Support
AlmasSuljevic
Message 5 of 8 (414 Views)
02-05-2013 07:16 AM in reply to: Topher5000
I have seen this behavior with the 2010 version if there is a viewport that has a DVIEW Twist applied to the viewport. I believe this was fixed in later releases. If you are using the DVIEW in the viewport, set the rotation to some 90 degree increment (0, 90, or 180) and see if the image lines back up with the linework as expected. Also see if you can bypass Data Connect and just insert the image into the drawing using "Insert Image".
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Please click on "Accept as Solution" if post helped you resolve the issue.
Valued Contributor
Topher5000
Message 6 of 8 (407 Views)
02-05-2013 07:34 AM in reply to: AlmasSuljevic
Hi again Almas.
I've tried inserting it with mapiinsert, a straight image insert & then scaling & positioning it, using the FDO connection, & xrefing it into another drawing, but it still does it.  I was going to move my linework to match the aerial in the viewports but the apparent position changes depending on how far I'm zoomed in.  Is there anything else to try?  We've got a public meeting coming up & I need to get this sorted out.
Valued Contributor
Topher5000
Message 7 of 8 (387 Views)
02-06-2013 09:30 AM in reply to: Topher5000
Got it working.
New Member
SteveXXX
Message 8 of 8 (109 Views)
06-28-2014 10:05 AM in reply to: Topher5000
Having same proble of viewport image shift using geolocate aerial.  Brought the image into individual sheets and move the xref line work to match image worked.
