<bpattengale> wrote in messageI've
href="news:6172764@discussion.autodesk.com">news:6172764@discussion.autodesk.com...
been running C3D 2010 for a few days now after switching from 2009. I'm
getting a reoccuring error wih the ribbion. The ribbon and quick access
toolbar will stop working. They are still visible on the screen and C3D hasn't
frozen or crashed I just can't select anything on the ribbon. I can still
access commands via the toolbars and menubar. The ribbon will do this at
random, however it seems to do this after Crtl-Tab switch between drawings the
most(not everytime). I've tried to close the ribbon or switch drawings, but it
still remains frozen. Currently the only way I've found to fix it is to
restart C3D. Has anyone else experienced this? Anyone know of a work around or
think that a reinstall or repair may make a
difference?
<neovader> wrote in messageI've
href="news:6172987@discussion.autodesk.com">news:6172987@discussion.autodesk.com...
seen a similar issue happen in other previous versions of CAD. When I had this
happen, it was because an input box or dialogue box was open off the screen
where you can't see it. So it looks like CAD is frozen but really it's just
waiting for input and you can't see the input window. If that happens again
try these things and see if it works: Try changing your screen resolution to
larger if possible, or smaller and see if that snaps the input window over.
Try press ALT, then Spacebar, then select Move, then press the arrow keys and
see if it moves the window back where you can see it. Hope this helps
Jesse
style="MARGIN: 5pt 0in; mso-pagination: none; mso-layout-grid-align: none">
face=Arial size=2>Civil 3D
2010
face=Arial size=2>Intel i7
Extreme Edition 3.20 GHz
"wfb" <
href="mailto:wfberry@bellsouth.net">wfberry@bellsouth.net> wrote in
message
href="news:6173254@discussion.autodesk.com">news:6173254@discussion.autodesk.com...
Just for the record. I have not seen
this.
YET !
Bill
2010
i7 Extreme Edition 3.20 GHz
Gigabyte MB
Corsair Dominator 12 Gb Ram
Fast Raid drives (2)
Nvidia GeForce 9800 GT
Nvidia GeForce 8500 GT
Using Windows 7 x 64 Ultimate
(Beta)
