I am getting the following fatal error when running
C3d 2010.
Unhandled e0434f4dh exception at 7c81eb33h
Sometimes, this error occurs on startup, and
sometimes it does not happen until I try to click on the ribbon.
I have submitted CER's a couple times and done
enough initial investigation to see that .Net 3.5 SP1 seems to be the
culprit.
I have already attempted the
following:
Repaired the .net installation
Repaired C3D installation
Uninstalled .Net 3.5 SP1 and reinstalled
it
Renamed the Civil 3D portion of the Registry in
HKEY_CURRENT_USER and let the C3D repair it
Uninstalled and Reinstalled Civil 3D
and I Still have this problem.
I installed the software yesterday and it was
running fine. I worked with it this morning and it was fine. Then, I
suddenly had the problem. Any additional suggestions/fixes would be much
appreciated, as I am dead in the water with this machine right now.
Chris
