Civil 3D Forum
C3d 2010 Cogo points not in prospector
4 REPLIES 4
tbronson
544 Views, 4 Replies
I have an existing drawing that I have picked cogo points for survey layout about 3 weeks ago.  Now when I open the drawing the points show up on the screen, but they are not in the prospector.  Where did they go?  What do I need to do to get them back in the prospector?
Todd
4 REPLIES 4
Jeff_M
in reply to: tbronson
When you select one in the drawing, what does it display in the Properties Palette?
tbronson
It's an AECC_POINT.
Jeff_M
That is a LandDesktop point, not a C3D point. In order to display in Prospector the points must be converted to C3D points. Perhaps this was previously done and either the drawing wasn't saved or you are using a different drawing.
tbronson
in reply to: Jeff_M
That did the trick.  I must have created the drawing when we were using LDT without realizing it.
Rail Community
