Thanks for the input Mia! These are some of the things that we are taking
seriously.
When you override parameters at some stations, in fact we are not adding a
"new region" (as some clients complained that adding too many regions per
edit is counterproductive - argumentatively), but the information is
provided to you.
In the Corridors Properties -> Parameters tab, please right click on the
region that you have overridden some stations to see an option "Overridden
Stations..."
This will bring up a dialog box with list of overridden stations.
Hope this will help, and thanks again for the wish items.
Chakri Gavini
Product Designer
Autodesk Inc
wrote in message news:4837701@discussion.autodesk.com...
If you edit a section in the new Corridors>View/Edit Corridors sections by
changing a subassembly value such as lane width it changes the Corridor at
that station (Oh make DARN sure you do not have your Corridor set to
"Rebuild - Automatic" or your V/E dialog will flash like a Christmas tree)
but when you look at the Corridor properties>Parameters there is no new
region to track the over-ride. How are you supposed to keep track of design
over-rides? What if you need to edit a region, what happens to the
over-rides?
Also, Can ADSK PLEASE add some of the little stuff we real users need like:
The ability to edit a section in a Corridor by selection
Create a Section view by selecting the section object
Quick section
Mia
