Civil 3D Forum
c3d '09, plain text changes location from x-ref base to pp model and paper space
2 REPLIES 2
190 Views, 2 Replies
I have text in a base dwg next to a c3d s.s. structure table. Looks fine in base dwg. In the plan/profile this is x-ref in the text is on top of c3d table text. visretain is 1, text is not annotative.
2 REPLIES 2
troma
Are you sure it's the text that's moving? Could it be the table? Draw a line or something to double check.
Mark Green
Working on Civil 3D in Canada
in reply to: troma
Thanks for the reply. I think it is the scaling of the pipe structure table
from a x-ref in model space to a viewport in paperspace. The text that is
out of place is just plain single line text.
Here is a pdf of the 2 situations.
David
David H. Collie
Designer, Project Coordinator, Civil Department
Phone: (919) 732-3883
Fax: (919) 732-6676
david.collie@summitde.net
Creatively Inspired - Technically Executed
0printing.> www.summitde.net
P Please consider the environment before printing.
This email and any files transmitted withit are confidential and intended solely for the use of the individual or
entity to whom they are addressed. This message contains confidential
information and is intended only for the individual named. If you are not
the named addressee you should not disseminate, distribute or copy this
e-mail. Please notify the sender immediately by e-mail if you have received
this e-mail by mistake and delete this e-mail from your system. If you are
not the intended recipient you are notified that disclosing, copying,
distributing or taking any action in reliance on the contents of this
information is strictly prohibited.
Rail Community
