I have created an assembly for a roadway section. I have my finish grade alignment along with the vertical profile. My assembly is matching the existing gutterline on one side of the road and I want to set the opposite side of the road at my profile finish grade. So far I have been only able to set up an assembly using a specified cross slope. I do not want a constant cross slope of the roadway based on my assembly I have created.
The question is.....Can I create an assembly where I can make the cross slope of the roadway determined by the target of my alignment finish profile grade? if so, how do I get pushed in the right direction.
Rick
You were specific about what subs yiu used in your assembly , but many have default setting that can be overridden when the corridor is being built "targets"
Your Name
Your Name
It would probably help if you can post a typical section sketch, showing exactly what you're trying to do with this assembly.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
