I recently installed C3d 2015 and came across some problems with my text. The drawing is showing these lines between different portions of text and will move/readjust when panning/zooming. It doesnt seem like its tied to a specific font type either...It seems as if it only occurs with existing drawings and civil 3d 2015 (all other C3D versions work properly). New drawings dont show these stray lines between text. Has anyone had this problem? know a solution?
Solved by hcrum87hc. Go to Solution.
@SSato54 wrote:I recently installed C3d 2015 and came across some problems with my text. The drawing is showing these lines between different portions of text and will move/readjust when panning/zooming. It doesnt seem like its tied to a specific font type either...It seems as if it only occurs with existing drawings and civil 3d 2015 (all other C3D versions work properly). New drawings dont show these stray lines between text. Has anyone had this problem? know a solution?
I haven't seen this issue. Are they C3D labels? Are they MTEXT objects or MLEADERS?
sorry, had a problem attaching the file due to our restricted internet. should be attached now.
SSato54 wrote:this basically means i need to recreate the entire drawing to get rid of this problem which likely wont happen.
Rather then recreating everything. Why don't you try to Wblock the text out, insert it in a fresh template and see if that clears it up. If not. Try a DXFout and In.
Allen
Allen Jessup
Engineering Specialist / CAD Manager
Not sure, but since I am not seeing any issues with your drawing in 2015 I can only guess that it is due to the Bigfont assigned to your text styles (which I do not have so another was used in it's place.) Try removing the use of Bigfont, or changing the font used, for the S-X styles and see if that clears it up.
That fixed it alright. I wasnt able to figure it out after playing with the fonts, so i reverted back to 2014. Thanks for the reply!
