Civil 3D Forum
bug SAC 2016
3 REPLIES 3
joantopo
263 Views, 3 Replies
bug SAC 2016
There are the auxiliary links AL9 and AL11 as you can see in the Preview, but...
If we want to create an Auxiliary Intersection or Intersection point from (1 or 2 links), then these links don´t appear in the list of the combobox...
I don´t understand what happens because these links really exist.
At the beginning, I tried with 2 auxiliary points to define these auxiliary links, but if the first point is not an auxiliary point (normal point) happens the same.
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
3 REPLIES 3
KMercier_C3D
in reply to: joantopo
Were those auxiliary links created in a decision higher in your flow chart and therefore don't always exist?
Kati Mercier, P.E. | LinkedIn | AutoCAD Civil 3D Certified Professional
Pronouns: She/Her
Co-author of "Mastering AutoCAD Civil 3D 2013"
AU2019 Speaker::: CES321590: Analyze and Revise Existing Subassembly Composer PKT Files for AutoCAD Civil 3D
AU2017 Speaker::: CI125544: Analyze and Devise in Subassembly Composer
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
KMercier_C3D
Pronouns: She/Her
joantopo
in reply to: KMercier_C3D
Exactly, is that.
I tried with new links, instead of auxiliary links, and now doesn´t appear L67 and L69 in the combobox.
But as you say, I don´t have L69 in both branches in each conditional.
Although I was checking the False Decisions, so I watched them in the Preview.
However, in the next Decisions I can check if I have one or two slopes in each side. (perhaps, I will have to invent some L67 and L69 in the True branch) : )
Rail Community
