Civil 3D Forum
buffer aound pipe network
8 REPLIES 8
Message 1 of 9
vngrupe
349 Views, 8 Replies
I have many alignment's plines with pipe network
could anybody say, how insert buffer arount that newtork
8 REPLIES 8
Message 2 of 9
annw2
in reply to: vngrupe
Do you mean offset alignments?
Ann Wingert, P.E.
Message 3 of 9
vngrupe
in reply to: annw2
I'm designing water/wastewater pipes network with civil 3d.
I need insert sanitary protection zone (buffer) arround these pipes network.
Message 4 of 9
troma
What is a sanitary protection zone (buffer)?
Mark Green
Working on Civil 3D in Canada
Message 5 of 9
vngrupe
in reply to: troma
I need sanitary zone around pipes network, such as buffer.
I can do it with lisp code, but maybe civil3d have this function?
Message 6 of 9
annw2
Yes, partly.  3d has the offset alignment function.
You said you alignments along the pipe centerline.  Home tab - Alignment, 2nd from the bottom - Offset Alignment.
Create 2 alignments with left (negative) and right (Positive) off set distances.
As you move the main alignment, these will follow.
I think you can have the alignments in sitesand draw parcel segments on the end to create full easements.
I only had one project about 5 years ago that I was starting to try out this function.
Ann Wingert, P.E.
Message 7 of 9
vngrupe
in reply to: annw2
Thanks, but that you think, about this zone's segment?
Message 8 of 9
Neilw_05
Map has tools to create buffers but it won't work with C3D objects such as alignments or pipes.If you convert your C3D objects to plain graphics then you can use the buffer tools.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
Message 9 of 9
Joe-Bouza
That would be offset alignments at the buffer width
Joe Bouza
Rail Community
