When i am making e-transmittal i am getting the message warning Xref broken refernce can you please tell me what are the causes for this.
thanks
Solved by dgordon. Go to Solution.
In the drawing you are sending, have checked to make sure that all the XREF's in the drawing are up to date and that the references are correct. Also check to see if the references in the drawing you are sending are Full Path or Relative Path references.
One other cause may be that there may have been references in the drawing originally but the drawings have been deleted as they are no longer needed however the reference of that drawing has not been deleted from the drawing you are trying to send.
HTH
No, your answer does not match with what i did yesterday , first of all i check where the xref is broken the details of it and than i observed that in the profiles the xref is broken so i went to the profile menu and re-establish the xref again and my problem is solved.
thanks for your answers.
