Hello!
When I divide an alignment to to parts, the lables of the second part are missing.
Can I assembley two alignments in one?
Thank you!
The segments all have to connect, end-to-end, in order for it to apply stationing to the entire length. Plus they all need to be created in the same relative direction. If the two parts are tangent segments, you can simply grip edit them so that their endpoints connect. Or, you can edit the alignment geometry and add an additional line or curve segment between them.
