Is anyone able to do this? It doesn't work for me. Put a pressure network pipe in a profile view and use the command BREAKPRESSUREPIPEINPV (it's on the Pressure Network Profile Layout: <Network Name> ribbon tab as well). Mine does absolutely nothing for me.
Solved by BrianHailey. Go to Solution.
Brian, you have to break it in plan view.
The Break in Profile View tool is just like war...What is it good for? Absolutely nothin'.
Hello Brian,
I am having the same problem over here. I just upgraded from CD 2013 and I was used to that command in my profile views. Have you managed to work around this issue?
I disagree with the previous user. This command is very helpful, specially when you are solving conflicts with other existing pipes.
BB
I think you mis-read Tim's note. It is useless because it does not work. At least that is what I thought.
Bill
I'm using C3D 2014 and you what I have to do is select edit network button in tool space and it ask if you want to edit pipe in plan or profile view. Don't know if they changed this in 2015. Hope this helps.
Andy
Just to follow up on this old post, this was fixed in a service pack. Make sure your software is up to date.
I'm using C3D 2015 SP3 and it still crashes as soon as I pick the pipe in profile. Breaking the pipe in plan still causes the second half to disappear as others have noted.
