I have a drawing that will not display LDT objects. I have been playing with this for the last couple of hours and I have figured out what sequence of events causes this but I do not know why.
If I start a new drawing with our company drawing template then insert a layout from our title block template I can no longer see new LDT objects that xrefed, inserted or created in the drawing. The layout was inserted using the LAYOUT command and the T option.
I was able to "fix" our drawing template by creating a new one from acad.dwt and updating the settings using the express tool sysvdlg. I compared the variables between the two templates and saw nothing that would cause this.
If anyone is daring enough to dive into this I would love to know what is causing it. I submitted this to subscription support also.
The attached zip file contains the following:
Cant see LDT Objects.dwg - drawing containing 110 contours and 972 AECC_Points that cannot be seen
JR Acad 2009.dwt - original drawing template used to create the new drawing
Title Block.dwt - contains the layout that was inserted into the new drawing created from JR Acad 2009.dwt
JR Acad 2009a.dwt - new template created from acad.dwt and changed sysvars to company settings
JR Acad 2009 vs JR Acad 2009a.pdf - file showing differences between old and new acad templates.
3964900EC.dwg - drawing containing 110 contour objects and one line to use for testing.
To recreate the issue as we original saw it:
Create a new drawing using JR Acad 2009.dwt as the template.
Using the LAYOUT command and T option insert the layout from Title Block.dwt.
Xref 3964900EC.dwg.
Zoom extents.
You should only see the line from the 3964900EC drawing and no contours.
Have fun with this one, if you dare. I will post back here with any response from Subscription Support.
Jeff Paulsen
Civil 3D 2020.4 | Win 10 Pro N 64-bit
Xeon W-2223 @ 3.60GHz, 32GB Ram | NVidia Quadro P2200
