Civil 3D Forum
boundary
5 REPLIES 5
309 Views, 5 Replies
boundary
lets say i have a boundary aroud something pretty massive. i look in the properties and see that it is not closed. is there a way to identify where in the boundary there may be a gap? sometimes these gaps are tiny, just downright microscopic.
5 REPLIES 5
jmayo-EE
I typically create a new pline much faster than trying to locate and correct errors. I use Props or PE to force the pline closed then I use the boundary (B) command to create a new pline. This can be done in seconds.
John Mayo
ToddRogers-WPM
Do a hatch and it will show you where it's not closed with small circles where the polyline doesn't close.
Todd Rogers
in reply to: ToddRogers-WPM
im sorry but i can't produce this effect. i have a 3dpoly as my boundary, i dont know if that matters. i also created a simple test 2d boundary to test this and still cant get the circles.
thanks.
ToddRogers-WPM
You have to use the Pick option and not the Select option in order for them to display.
Todd Rogers
i see them now. its weird, they dont show up every time. thanks.
Rail Community
