KY9
Member
KY9
Message 1 of 7 (387 Views)
Boundary Survrey Labels
387 Views, 6 Replies
11-01-2012 07:26 PM
I have to label a boundary survey, then rotate the entire boundary while keeping the bearing and distance intact.
Is there a way to label the entire boundary and rotate it without changing the bearing data.
Or at least disable the dynamic feature of the bearing so that it doesn't change with each rotation.
Thanks for the help.
mathewk
Message 2 of 7 (378 Views)
Re: Boundary Survrey Labels
11-01-2012 09:29 PM in reply to: KY9
I'm curious, what's the purpose of rotating things if you don't want to change the bearings?
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
KY9
Member
KY9
Message 3 of 7 (369 Views)
11-02-2012 05:20 AM in reply to: KY9
Good question. As a surveyor, you want to show the deed bearing and distance in comparison to the new/actual bearing and distance. A lot of old deed information was based on 1927 coordinates or on a different coordinate adjustment system and current survey requirements are based on one requirement.
You have to reference where you got your research data from. And if you happen to have 2 deeds/parcels that are adjoining but have different bearings, you have to show this. And show the new bearings based on current coordinate adjustments.
mathewk
Message 4 of 7 (362 Views)
11-02-2012 06:16 AM in reply to: KY9
How about xrefing the old deeds/parcels complete with their labels into a new dwg with the new deeds , rotaat, move, and scale the xref as required?
Matt Kolberg
Distinguished Contributor
jefflambert9091
Message 5 of 7 (351 Views)
11-02-2012 07:33 AM in reply to: KY9
If you are keeping the deed lines the same and just rotating for the final survey you could create a style that shows the original deed bearing and the current bearing. You can create an expression adding or subtracting the angle rotated from the segment direction and add it as part of the label.
It would not be efficient if each line was a different rotation. We have a general line label style to manually type in a deed bearing and/or distance. We use this if we only have a few.
Distinguished Mentor
rl_jackson
Message 6 of 7 (343 Views)
11-02-2012 08:09 AM in reply to: KY9
Something that I routinely do, is have a parcel with lables at the originial bearing base, and another thats rotated. I explode the original lables twice to make them mtext, then I make them annotative (for scaling purposes) and move them to the new lines. Simply and I still have the original parcel along with the new parcel in my drawing.
C3D12-13
Win7x64 6gb
KY9
Member
KY9
Message 7 of 7 (318 Views)
11-02-2012 02:47 PM in reply to: rl_jackson
Thanks guys. I have been doing the same method that rl_jackson is talking about.
I just thought maybe there was an override or a way around exploding the 'segment labels'.
Thanks again for the help and additional ways of doing it.
