If you import a fieldbook with a field survey you can then do a traverse
adjustment which will report the misclosure of your measurements.
If you have defined a parcel - the parcel will be closed to the limit of
accuracy of AutoCAD and there can be no meaningful way of reporting a
misclosure distance/direction with AutoCAD based tools.
However there is another misclosure option which reports the misclosure of
the parcel on the presumption that its sides are measured for azimuth and
distance and the current C3D precision settings.
Laurie Comerford
CADApps
www.cadapps.com.au
www.civil3Dtools.com
wrote in message news:5675685@discussion.autodesk.com...
to create a parcel in civil 3d i have to have a closed polyline....obviously
it closes and nothing in the parcels functionality will help me
how do i check for closure with a traverse or existing boundary? is
something in the survey toolspace?
