Civil 3D Forum
BLURRED IMAGE PLOTS
8 REPLIES 8
Message 1 of 9
2582 Views, 8 Replies
BLURRED IMAGE PLOTS
I started having a problem plotting to an HP Design Jet 1055CM with 2008. Everything on the sheet plots OK, except for image files (USGS Topo Maps, Aerial Photo, etc), they come out blurred.
8 REPLIES 8
Message 2 of 9
If you plot to a DWF or PDF then to the plotter, are they also blurred? This will help determine if it is Civil 3D causing the problem or your plotter driver/plotter.
Message 3 of 9
Yes, If I plot the image from Microsoft Document Imaging ArcMap 9.1 or Adobe, they all come out clean. They only blurr when plotting from AutoCAD.
Message 4 of 9
How are you attaching the images? If you are using the Data Connect and
"attaching" then it's a know bug, using the Map image attach should work.
Murph
The world is not FLAT so why is your GIS data?
http://map3d.wordpress.com
wrote in message news:5757026@discussion.autodesk.com...
Message 5 of 9
I've attached them using standard image insert, Map Image Insert and Data Connect raster connect in AutoCad, I've tried all three in Civil 3D and Raster Design, same problem. Only the image blurrs everthing else (lines, circle,etc) come out clear.
Message 6 of 9
You can check your Plotter Configuration Settings. The Raster Graphics my need to be turned up. See Attached Image
Message 7 of 9
Already tried, didn't work. Thanks
Message 8 of 9
Message 9 of 9
Problem fixed by using Map Image insert, instead of using DATA CONNECT Raster Image, it blurrs the Image.
Rail Community
