Civil 3D Forum
Block in Point Label in XREF color issue
3 REPLIES 3
KirkNoonan
322 Views, 3 Replies
Here's a weird one. I have a block tha I use in a point label style. All of the block entities are on layer 0. The label style is also set to layer 0 so that it get on the same layer as the point. I've tried setting the block color in the label at by layer and by block. When a drawing that contains this label style is XREF'ed into another drawing, the block in the label always takes on the color of the current layer. Am I overlooking something?
Kirk
C3D 2011, Version 3
edit: I attached an example. The top figure is the point with the block in the label and the bottom is just the block itself.
3 REPLIES 3
MarySeufert
in reply to: KirkNoonan
This is a known issue...
See this thread and the others linked in it.
Solution in regards to plotting issues that stem from this is to make sure your current layer is set to '0' before plotting.
~ Mary
EXPERT ELITE MEMBER
mathewkol
I'd prefer not to use layer 0 within the block. Having to remember to set the current layer to 0 before printing is not as reliable especially when you have others printing your files.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
mathewkol
Obviously neither workaround is ideal.
Matt Kolberg
Rail Community
