Here's a weird one. I have a block tha I use in a point label style. All of the block entities are on layer 0. The label style is also set to layer 0 so that it get on the same layer as the point. I've tried setting the block color in the label at by layer and by block. When a drawing that contains this label style is XREF'ed into another drawing, the block in the label always takes on the color of the current layer. Am I overlooking something?
Kirk
C3D 2011, Version 3
edit: I attached an example. The top figure is the point with the block in the label and the bottom is just the block itself.
