Hi all,
As the subject line says, when I select objects in the block editor window I cannot see/autocad does not display (?) the selection fence. Has anyone else had this problem or know if there's a sysvar for this?
Solved by tcorey. Go to Solution.
It works fine for me. Try changing the background color in Block Editor (Options, Display tab, Colors) and see if you get different results.
Worked fine for me as well. Thanks to that suggestion, it works fine again. Thanks Tim.
I had changed the background color, but the fence didn't "disappear" right away so I hadn't considered that. Now it's apparently fine with the alternate color. Quirky AutoCAD..
