Valued Contributor
jamesbarnett
Message 1 of 3 (171 Views)
Block constraints. How do I hold a line to txt length?
171 Views, 2 Replies
01-15-2013 09:00 AM
I am using Civil3D 2012 SP 2.
I am creating a block for my details. I want to be able to title my block and the the line under my txt will change it's length based on the lenght of the text. I keep playing with the constraints, but I haven't found one that is doing what I want.
AutoCAD Civil 3D 2014 SP 1
Windows 7 (64)
tcorey
Message 2 of 3 (165 Views)
Re: Block constraints. How do I hold a line to txt length?
01-15-2013 09:30 AM in reply to: jamesbarnett
One solution would be to underline the text.
When typing text to be underlined, preface it with %%U. For example: %%uTitle will be Title. Changing the text will change the underline.
Another way would be to use a Civil 3D Note object (but it can't be part of a block) and underline or create a line component that uses start and end of the text component as its start and end points.
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
Valued Contributor
jamesbarnett
Message 3 of 3 (160 Views)
01-15-2013 09:50 AM in reply to: tcorey
I thought of those options, but I kind of wanted the line a different color and I want to do it all in a block so it will be seemless.
Windows 7 (64)
