I have a drawing from a consultant where they have done a custom rotation on the block attributes so that they don't match the rotation of the block. Is there any way that I can get the rotation of the attributes to match the rotation of the block without doing each one individually?
Melody
Solved by rfg018. Go to Solution.
Thanks! ATTSYNC would have worked if the block had been created with attributes. I just discovered that the text is not an attribute
Melody
The last time check, block can not be "plan readability". C3D 2009
Your options are to explode the block and change the text.
or
block edit, and change the text to an attribute, so it can auto-rotate.
You can set the default text to the existing text.
