"Zdenko Novkovic" <
href="mailto:znovkovic@tidesign.biz">znovkovic@tidesign.biz> wrote in
message
href="news:5837285@discussion.autodesk.com">news:5837285@discussion.autodesk.com...
Well at least we are beginning to get some honest
answers. I was advocating a secondary layer system for all styles labels and
not just one item.
I will upload the two zip files of two
small projects and would like either of you (or others) to tell me how
long it would have taken you to generate the work. I will tell you time
spent using C3D and time spent using LDD and what my margins were?
Please understand that this is not a way for me to marginalize one ove the
other. I just would like an honest answer. They will be posted on
autodesk.dwf under Scope of
Work.
Jon you have a very broad cliche in use when
claiming "how fast" v. "how slow"? I have seen some very fast people who have
put much effort in ensuring that they stay competative with LDD and are still
doing an excellent job of it and you will find them hard pressed to make the
change.
Z. Novkovic, PE
Terra Integrated Design, LLC
href="http://www.tidesign.biz">
size=2>www.tidesign.biz
size=2>PowerCivil/C3D
<sinc> wrote in messageThere isn't a "double system of
href="news:5837325@discussion.autodesk.com">
size=2>news:5837325@discussion.autodesk.com
size=2>...
layers"...
We use Styles and Layers together. It isn't a simple
system, but it works well. For example, I can use a surface Style to
control the display of individual surfaces. But my Style puts all the
TIN lines on a specific layer, so I can turn TIN lines on/off for all surfaces
at once by using the layer, even though the surfaces may be using different
display styles.
C3D will work if you put everything on Layer 0 and use
only Styles to control visibility. But you lose a lot of flexibility
that way. And if you need to share drawings with people who are NOT
using C3D, you can create a disaster for them if you put everything on Layer
0.
Now, I really dislike some of the things Autodesk did, like put
Parcel Labels on the "Parcel Segment" layer. That sort of thing creates
an awful lot of problems. Also, they should include a way of selecting
an item and freezing the "apparent" layer, rather than the "real" layer.
For example, if my Point is on Layer 0 and my Point Style puts my Point Marker
on my MONUMENT-SYM layer, I want to be able to pick the Point Marker and
freeze/turn off the MONUMENT-SYM layer, and NOT Layer 0.
But these
things can be worked around.
"Zdenko Novkovic" <
message
href="news:5837375@discussion.autodesk.com">news:5837375@discussion.autodesk.com...
OK the site will not allow me to post? What was
the NG for uploading files?
Z. Novkovic, PE
Terra
href="http://www.tidesign.biz">www.tidesign.biz
PowerCivil/C3D
"Zdenko Novkovic" <
message
honest answers. I was advocating a secondary layer system for all styles
labels and not just one item.
two small projects and would like either of you (or others) to tell me how
Work.
when claiming "how fast" v. "how slow"? I have seen some very fast people
who have put much effort in ensuring that they stay competative with LDD and
are still doing an excellent job of it and you will find them hard pressed
to make the change.
Z. Novkovic, PE
LLC
size=2>...
of layers"...
simple system, but it works well. For example, I can use a surface
Style to control the display of individual surfaces. But my Style puts
all the TIN lines on a specific layer, so I can turn TIN lines on/off for
all surfaces at once by using the layer, even though the surfaces may be
using different display styles.
on Layer 0 and use only Styles to control visibility. But you lose a
lot of flexibility that way. And if you need to share drawings with
people who are NOT using C3D, you can create a disaster for them if you put
everything on Layer 0.
Autodesk did, like put Parcel Labels on the "Parcel Segment" layer.
That sort of thing creates an awful lot of problems. Also, they should
include a way of selecting an item and freezing the "apparent" layer, rather
than the "real" layer. For example, if my Point is on Layer 0 and my
Point Style puts my Point Marker on my MONUMENT-SYM layer, I want to be able
to pick the Point Marker and freeze/turn off the MONUMENT-SYM layer, and NOT
Layer 0.
But these things can be worked around.
"Zdenko Novkovic" <
message
href="news:5837286@discussion.autodesk.com">news:5837286@discussion.autodesk.com...
ok it should be under
autodesk.autocad.customer-files just waiting to see if the first one gets
loaded...rejected again...maybe i will try to uplad each one
seperately...
Z. Novkovic, PE
LLC
PowerCivil/C3D
"Zdenko Novkovic" <
message
Z. Novkovic, PE
Terra
PowerCivil/C3D
"Zdenko Novkovic" <
in message
time spent using C3D and time spent using LDD and what my
margins were? Please understand that this is not a way for me to
marginalize one ove the other. I just would like an honest answer. They
will be posted on autodesk.dwf under Scope of
Work.
and are still doing an excellent job of it and you will find them hard
pressed to make the change.
Z. Novkovic, PE
Terra Integrated
Design, LLC
size=2>news:5837325@discussion.autodesk.co...
size=2>...
system of layers"...
isn't a simple system, but it works well. For example, I can use a
surface Style to control the display of individual surfaces. But my
Style puts all the TIN lines on a specific layer, so I can turn TIN lines
on/off for all surfaces at once by using the layer, even though the
surfaces may be using different display styles.
C3D will work if
you put everything on Layer 0 and use only Styles to control
visibility. But you lose a lot of flexibility that way. And if
you need to share drawings with people who are NOT using C3D, you can
create a disaster for them if you put everything on Layer 0.
Now, I
really dislike some of the things Autodesk did, like put Parcel Labels on
the "Parcel Segment" layer. That sort of thing creates an awful lot
of problems. Also, they should include a way of selecting an item
and freezing the "apparent" layer, rather than the "real" layer. For
But these
"Jeff Mishler" <miffATsonicDOTnet> wrote in message
href="news:5837288@discussion.autodesk.com">news:5837288@discussion.autodesk.com...
ZIP it Z, for whatever reason the forum software doesn't
like most files posted from OE. Add it to a ZIP file and it will most always
work.
"Zdenko Novkovic" <
message
seperately...
Z. Novkovic, PE
LLC
PowerCivil/C3D
"Zdenko Novkovic" <
in message
was the NG for uploading files?
Z. Novkovic, PE
Terra
PowerCivil/C3D
"Zdenko Novkovic" <
wrote in message
of two small projects and would like either of you (or others) to tell
me how long it would have taken you to generate the work. I will
tell you time spent using C3D and time spent using LDD and
what my margins were? Please understand that this is not a way for me to
Work.
use when claiming "how fast" v. "how slow"? I have seen some very fast
people who have put much effort in ensuring that they stay competative
with LDD and are still doing an excellent job of it and you will find
them hard pressed to make the change.
Z. Novkovic, PE
Terra
face=Arial size=2>www.tidesign.biz
size=2>news:5837325@discussion.autodes...
size=2>...
my Style puts all the TIN lines on a specific layer, so I can turn TIN
lines on/off for all surfaces at once by using the layer, even though
the surfaces may be using different display styles.
C3D will work
if you put everything on Layer 0 and use only Styles to control
if you need to share drawings with people who are NOT using C3D, you can
Now,
I really dislike some of the things Autodesk did, like put Parcel Labels
on the "Parcel Segment" layer. That sort of thing creates an awful
lot of problems. Also, they should include a way of selecting an
layer. For example, if my Point is on Layer 0 and my Point Style
puts my Point Marker on my MONUMENT-SYM layer, I want to be able to pick
Layer 0.
