We are creating lines by Best Fit and want to be able to control the resulting Panorama window showing the results.
Using Lines/Curves menu-Create Best Fit entities-Create Lines-From COGO Points then we click on the Cogo Points in the drawing. The resulting Panorama window shows the results of our best fit line but the point numbers listed start with "1..2..3" and so on rather than using the C3D point number of the points we've chosen. When we export this out to a text file for later use the only way to determine which points were used is to look at the coordinate listing and figure it out from there.
Is there a way to control the resulting Panorama window so that it will display the Cogo Point number rather than sequential order by points chosen?
Anyone have an answer to this? I am guessing there isn't one.
Wishlist item perhaps....
