I am setting up M&B labels and tryinh to get a leading zero in the direction. I have a 9 deg angle and when I drop the leading zero in the label I get N009. I would like to see N09. Is ther a setting I am misiing? Something is inconsistant in the attachment as well. Both the delta and ch direction have the leading zeros turned on. Why does 9 deg show as 009 and 24 deg show as 24?
John Mayo
Thanks John but that did not work. I am thinking I should be able to set the label to drop the zero and perhaps use an IF statement in an expression to get the leading zero...
John Mayo
This is a pretty big bummer for our surveyors. I have no had luck with an expression.
Do you have any workaround outside of programming one?
John Mayo
Here is the solution I found for removing the Leading Zeros, at least from Angles.
Toolspace -> Settings -> Edit Drawing Settings (right click on drawing name at the top)
Select Ambient Settings Tab.
Under Angle modify the setting "Drop Leading Zeros for Degrees" to YES
Now for the irritating part. You have to edit the Label Style that you want to change. Selecting the Angle Component that needs to be modified and deleting it. Exit Component Editor. Go back into Component Editor and reapply the Angle Component you want.
Hope this is somewhat helpful,
Scott Ross
John,
Were you seeing N009 or was that a typo? If you actually seeing that. It's an anomaly. I can't recreate that.
Allen Jessup
CAD Manager - Designer
