Active Contributor
JOVO85
Message 11 of 17 (892 Views)
Re: Bearing and Distance Label
03-28-2012 08:58 AM in reply to: sjg
They are all set to "Layer 0" and turned on
Joseph-
Civil 3D 2012
Windows 7 Service Pack 1
Intel Core i7-2600 CPU
16GB RAM
tcorey
Message 12 of 17 (887 Views)
03-28-2012 09:02 AM in reply to: JOVO85
Call me at 530.221.2994 and I will help you through this. I have remote support capability so we can connect and look at it together. Should take us five minutes.
Tim
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
Active Contributor
JOVO85
Message 13 of 17 (874 Views)
03-28-2012 09:42 AM in reply to: tcorey
Thanks so much Tim, and thanks to everyone else who posted.
The problem was definitely some form of drawing coruption. After an audit and recovery, then wblocking and inserting into a working drawing I can report that order has been restored to the universe. I just learned from a colleague that a portion of the survey was done in land desktop so I'm going to blame it on that.
Thanks again, you'll be seeing more of me:smileyhappy:
Joseph-
Civil 3D 2012
16GB RAM
Active Member
rasterized
Message 14 of 17 (477 Views)
08-08-2013 09:31 AM in reply to: JOVO85
I can not add 'Single Segment' labels to 'Line and Curve's in my drawings either, requiring me to reference them into new ones as a work around.  Fix?
troma
Message 15 of 17 (455 Views)
08-09-2013 08:05 AM in reply to: rasterized
Have you tried:
Close the drawing and reopen?
Recover the drawing?
Audit the drawing?
Close the program and start it again?
Shut down the machine and reboot?
You're generally better off starting a new thread rather than posting to an old one that has been solved, and is probably not you're issue (or yours would be solved too, right?).
Credit where credit is due! Give kudos or accept as solution whenever you can.
Member
csully58
Message 16 of 17 (91 Views)
09-15-2014 10:19 AM in reply to: tcorey
Thank you, your video was very helpful. I am very new to Civil 3D and the biggest hurdle I have found so far is annotation. Another hurdle I am looking at is disassociating a label from line. Not sure if you have any help on this.
Charles Sullivan
charles@asam1.com
wfberry
Message 17 of 17 (74 Views)
09-16-2014 06:18 AM in reply to: csully58
You can explode the label.  I do not recommend this.
Bill
