Active Member
kfisher50
Message 1 of 34 (1,520 Views)
Bearing and distance info needed between two points
1520 Views, 33 Replies
08-18-2011 08:46 PM
I am a very recent convert to Civil 3d (within the last week, in fact!) -- I have been using LDD for many, many years.  As a surveyor, one of the routines that I most use is determining the bearing and distance between two points.  I have not been able to find a method to accomplish this task in a simple and speedy way in Civil 3d.  Drawing a line between the two points in question and then listing the line's properties (and then having to delete the line when finished) seems like a waste of steps, especially when compared to what it took in LDD.  The "Help" section does not address this problem, so I'm hoping to get some feedback from this forum.
Thank you for your input!
Sinc
Message 2 of 34 (1,519 Views)
Re: Bearing and distance info needed between two points
08-18-2011 09:30 PM in reply to: kfisher50
I think most people use the DIST command. There's also the Inquiry tool, although that's not as accessible as the DIST command.
I prefer the PTINV command.  It's only available in the Sincpac-C3D, a third-party add-on, but it gives much more useful output than the DIST command, including both 2D and 3D distances between your pick points.
Sinc
Active Member
kfisher50
Message 3 of 34 (1,516 Views)
08-18-2011 09:39 PM in reply to: Sinc
Thank you for your reply.  I have tried the "DIST" command, but it only returns a horizontal measurement between two points -- it unfortunatelly doesn't provide a bearing to go along with the distance.
AllenJessup
Message 4 of 34 (1,496 Views)
08-19-2011 05:59 AM in reply to: kfisher50
Are you looking for the Brng & dist between 2 AECC points of just any 2 points you can pick in AutoCAD?
Allen
AllenJessup
Message 5 of 34 (1,494 Views)
08-19-2011 06:11 AM in reply to: kfisher50
You can just the Inquiry Tool and select the Point1 and Point2 coordinates from anything you can snap to.
See Attached image.
But the best way to get an inverse between 2 points is the use he CGLIST command. You can list the info on a line or curve by selecting the object or you can select Points and snap to end, mid, center points or any other point you can usually snap to. You can also us the Transparent  Commands to snap to AECC points by name or number or Select the Point Object.
Allen
Active Member
kfisher50
Message 6 of 34 (1,476 Views)
08-19-2011 07:24 AM in reply to: AllenJessup
Allen:
This problem involves two aecc points...
Active Member
kfisher50
Message 7 of 34 (1,473 Views)
08-19-2011 07:27 AM in reply to: AllenJessup
Thanks Allen -- I'll give it a try.
Valued Contributor
JRedell
Message 8 of 34 (1,467 Views)
08-19-2011 07:47 AM in reply to: kfisher50
Point Inverse through the Inquiry Tool is the best way I've found to accomplish what you're trying to do. One thing that still baffles me about C3D though is it's inability to just place a label between two points in space and not be tied to a line.....
JRedell, PLS
Erlandsen
Civil3d 2012
Intel Core 2 Quad 2.66GHz
Win7 64bit
Quadro FX1700 (Driver 265.70)
8GB RAM
Active Member
kfisher50
Message 9 of 34 (1,464 Views)
08-19-2011 07:56 AM in reply to: JRedell
Thanks for your reply.  From the feedback that I've heard from other surveyors who have migrated (or rather forced!) to Civil 3d, this software does not lend itself very well to the needs of surveyors.  Or maybe it's just that we surveyors are a difficult bunch of SOB's who are hard to please!  LOL!!
Valued Contributor
JRedell
Message 10 of 34 (1,459 Views)
08-19-2011 08:01 AM in reply to: kfisher50
Well, that's a fact! We are a bunch that's fairly resistant to change, but that one issue has kept us from migrating for the last 4-5 years. As I'm sure you know....that's a much needed feature in the surveying world! Without it, plats and ROS's are very difficult to draft.
JRedell, PLS
Erlandsen
Civil3d 2012
Win7 64bit
8GB RAM
