Hello, does anybody know how to batch export civil 3D DWGs to LandXML files?
I've some hundreds of DWGs with DTM points, contours and breaklines, each corresponding to a grid with 1sq km. Now I am told to convert them into LandXML (v 1.2) files, but I can't see any batch option to do this. Any help would be appreciated. Thanks!
Solved by AllenJessup. Go to Solution.
I fear you can't, because you may export single surfaces to LandXML, and NOT whole drawings, sir.
As far as I know. It's not native to Civil 3D. You might be able to write a Script File and call it from a Batch file to do a folder at a time. You can run XML Export from the command line using -AeccLandXMLOut. But if you don't have standard surface names it will be difficult to choose what to export in each file. If you have hundreds of drawings as you said. If might pay to look for a 3rd party programmer to create a custom routine.
Allen
Allen Jessup
CAD Manager - Designer
